Posted July 23, 201213 yr comment_396614 Hi all,I'm finally at the stage were I am ready to install my Stahl headers and either I'm missing a hardware installation kit or I will need to notch the intake manifolds at the lower common studs as the header flange is thinner than the area around the intake. I sent a note off to Stahl as they are gone for the day but I know I didn't receive any hardware and I need to get on with this installation so any help is greatly appreciated.Thanks! Link to comment https://www.classiczcars.com/forums/topic/43893-stahl-header-installation-question/ Share on other sites More sharing options...
July 24, 201213 yr Author comment_396624 Hi all,I'm finally at the stage were I am ready to install my Stahl headers and either I'm missing a hardware installation kit or I will need to notch the intake manifolds at the lower common studs as the header flange is thinner than the area around the intake. I sent a note off to Stahl as they are gone for the day but I know I didn't receive any hardware and I need to get on with this installation so any help is greatly appreciated.Thanks! ok figured it out, stepped washers to manage the difference between the Stahl header flange and the intake. Link to comment https://www.classiczcars.com/forums/topic/43893-stahl-header-installation-question/#findComment-396624 Share on other sites More sharing options...
