Skip to content
Copper exhaust manifold gasket
On a turbo motor its significantly stronger than a conventional paper/metallic gasket and resists blowing. For a NA motor i cant see any advantages except it might last forever
Copper also conducts heat better, and the more heat you can keep in the exhaust stream the better the turbo performs, since heat = energy. The manifold might get a bit hotter as a result of using a copper gasket, thus keeping the stream a tad warmer.
