Skip to content
Corroded Turn Signal?
So I take off the covers on my front turn signals and the driver side looks good however the passenger side seal must have leaked because all the reflective chrome is heavily eaten away.
Here's the driver side
And here is the passenger side
It seems that only that reflective strip has been eaten away, is that a piece you can buy individually this seems like a problem that could be relatively common?
looks easy enough to reproduce using chromed plastic panels. You can get them in bathroom supply aisle at most hardware stores, they cut with a utility knife or snips.
