Skip to content
JDM Style Tail Lights
Any progress on this noodle?
I haven't really done anymore with this,
but one thing I have noticed is that the resin I had used is starting to degrade,
maybe I should have sealed it with a clear coat of paint.
even if had had some more, I would not feel confident enough to sell them sorry.
Nigel
  • 5 months later...
Hey Noodle, I was thinking about the work you did here last night. I've got 2 of the number plate plastic lenses that I need to make replacements for.
Do you reckon I could use this method? What have you done with all your equipment?
Hi,
I still have my gear,
I'm not sure how the resin would go with the heat from the light,
You could do this, with out any gear, and since its a small part. it should not be to hard
http://www.alumilite.com/howtos/TailLightMoldingEquipment.cfm
Nigel
  • 9 months later...
I maybe a little hated for bringing up an old thread but did you make anymore sets f/s?
No,
I was not happy with the resin I used to make the lens with,
it deteriorated in the weather.
Nigel
Ah bugger! Well if it would be ok could I purchase the moulds off of you if you still have them? Or should I make my own? Cheers for the response! - Owen
