I was right about those drums sucking. First wheel cylinder took me some time. Realized, after a bit of pondering, that it was best to install the rubber on the back as you install the cylinder from the front. Once cylinder get to a certain point getting the rubber on becomes impossible. Just best to slide them together as you go.
First set of shoes took too much time as well. Made the mistake of trying to put the lower spring in last. Oops. Had to remove the shoes completely and install both with lower spring installed already. Everything went smoothly afterwards.
No pics right now but the new hardlines fit pretty good.
Removed old brake and clutch master cylinders. Will be installing those this morning. After their installed, going to use some coke bottles and a ton of old (good but opened a long time ago) DOT 3 brake fluid to flush the hard lines before I make the connection to the wheels.
Decided to go with DOT 4 fluid rather than silicone DOT 5. Don't want the hassle of silicone being hard to bleed and possible sponginess. And it seems if I flush and bleed my brakes once a year or so I can mitigate the moisture issue and make even a glycol based last a long time without having to rebuild everything every 4 or 5 years.
Have to do driveshaft ujoints after brakes while still on the jackstands. Going to buy the ball joint tool from harbor freight everyone seems to recommend. I want to do all 6 but I will probably just to the main shaft since the forward shaft joint is the one with all the play. I want to have this car on the road soon and it's going to rain today and tommorrow and the next day...bleh.
Been watching the Just SU DVD so I can be ready to tune the carbs once the mechanicals are done. Also bought DeoxIT to start working on the wiring. First by disconnecting and cleaning the existing connectors. Finding grounds and cleaning them. Then making since of the wiring mods that have been done so I can figure what needs to be fixed there before I can do my own mods for headlight and parking light harness.
You know the more stuff I complete then more I figure I have to do. Haven't even mentioned steering and suspension, rust repair, interior install.... My wife just might forget she has a husband. Nah. Not possible. According to her I leave grease track in the house just by looking at it. So there's proof of my existence :)
Brakes completed as well as clutch hydraulics. Brakes very soft and need more bleeding. Guess that's to be expected with a complete rebuild of the whole system. Hopefully sitting over night will let the air bubbles settle to toward the bleeders.
Took it for the first drive. Just did a quick tune on carbs with Unisyn and Just SU info. Airflow was in balance but idle is still to high. Was too impatient to continue the tune so I just hopped in and drove her around the block. Man those brakes are soft. She shifts great but still need a little more throw on the clutch. She grinds going into reverse with clutch down if there is any forward movement. Another thread or two on the slave shaft should solve that.
Disappointed in how it ran though. Not surprising since she hasn't been on the road in years and I'm still working out a ton of bugs in her system. Going back to ground zero and setting valve lash cold and hot. Then setting timing. Then tuning carbs as best I can without removing them. Hope I can get her to run smoother on the road.
Little concerned about the oil pressure continuing to drop on the guage. Wouldn't worry me much except there seems to be a corresponding change in engine noise. Like she really is loosing oil pressure. Have a new sender I'm going to install. Maybe that'll solve that issue. Oil level is full and it's a new pump. Wish I had bought the L28ET pump. Get more flow and piece of mind. Oh well. That money is spent already.
Running out of cash fast on this project. As expected, just kinda hoped I be further ahead at this point.
Still have a mass of wiring issues to work out. Like why is the fuse panel in the glove box? Why are so many connectors not connected and what do all the extra wires running through the car go too? Schematics are useless at this point cause it seems few of the circuits are actually working as designed. Instead extra circuits and inline fuses are throughout the mismatched and heavily spliced harness. This part is gonna be a nightmare. Wish I had a whole stock harness I could just cleanup and drop in so I could start off stock. Oh well. I knew wiring was gonna be an issue from the start. One thing I had known about these cars. They rust and they have wiring issues. If anything is gonna make me give up on this car it'll be wiring.
Carbs wouldn't tune. Pulled float bowls and discovered the floats were maxed out high. Car would run faster if I raised the cylinder while she idled. Running extremely rich. Including a pic of the float levels below. Now I need new gaskets before I can continue. Should have thought of this when I ordered the Unisyn amd Just SU dvd. Didnt want to buy whole rebuild kit though it could use it. But shoulda atleast bought float gaskets.
Lesson learned. I can play with wiring while I wait for gaskets. Not like I lack work on this car.
Weather yesterday was horrid. Alot of high wind and hail. We have alot of trees in our yard. Oak and Magnolia. Only owned this house 4 months now. With spring coming the trees were finally showing leaves again and it was starting too look nice. One of those good size oaks decided to fall over on the neighbors house. Clearly it was rotten and weak at the base. But there was no sign on the outside. It appeared to be a healthy tree. Praying insurance does it's job on this. The car has now offically dropped low on my concerns list. There's some pics below. BTW noone was hurt and the room below was empy except for a few items stored inside.
Still waiting on my float bowl gaskets. Decided to clean the garage this last couple days rather than continue work on the Z. Hopefully I'll be able to park and work in my garage rather than constantly laying on dirty, often wet, concrete.
Did manage to drag my wife out to help me bleed brakes again. Usually use a mightyvac. I'm no longer get air from bleeding and just get a solid and firm stream. Brakes seem better but still not quite what I am expecting. Carbs are disassembled so I can't crank her. So without power booster affecting the pedal I expected something harder. But it's not. It's like I have 5 inches of pedal throw but brake only applies in the last 1 or 2 inches. That seem normal? Please keep in mind I've never driven a Z. No real clue how the brakes on this car should feel.
I could actually use help with this one.
Edited by EverRude
Figured out the brake problem. After a bit of seaching I discovered the adjustment to the booster rod. It was adjusted almost all the way in. Making a good 3 or 4 inches of travel at the pedal before the rod even touched the master cylinder. Adjusted it out and now I travel maybe 2 inches before I feel the brake pressure and it stops firm well before the floor. Happy with that result atleast.
Found another issue though. There's a nail stuck in the tread of the drivers rear tire. Not actually leaking but I aint gonna leave it. It's a tiny nail and I would have to enlarge the hole to use a plug. Thinking about using that green slime stuff. I have 2 cans of it I've never used. The tires will only be on the car another 500 miles or so before I get new ones. So it shouldn't hurt to use that crap since I have some already. Anyone use this product? Does it work to patch a tiny nail hole?
I wont be the one changing tires. :P
Just hate enlarging hole for a plug. It's in a bad spot too. Edge of tread and sidewall. Still in tread but that area gets more stress than any other in the most critical situations.
I will get new tires but the car needs so many other things first. I'll check around local used tire places. Maybe can find a used one or a whole used set for a reasonable price and enough tread to warrant the effort.
Edited by EverRude
Figured out the brake problem. After a bit of seaching I discovered the adjustment to the booster rod. It was adjusted almost all the way in. snip....
I am having the same problem. Please explain the adjustment or thread where you found the solution.
Also, around my area if you take the wheel to Discount Tire they will patch it for free whether you purchased the tire there or not. I've done this many times.
Good luck with the car and the insurance company.
John
Thanks for the tip JohnnyO.
The booster rod adjustment is fairly simple. Remove the master cylinder. You will see a rod. It has a small 7mm nut at end of rod. The rod also has serated teeth just below the nut. You will see the threads between the nut and the teeth. Just hold the teeth with a pair of pliers and turn the nut counterclockwise till it extends the amount you need. Finally reinstall the master cylinder and test.
I did have an issue trying this. My rod was corroded badly and I could not get the rod to turn. A more patient person would use something like PB Blaster or Liquid Wrench and made the adjustment after the a day or 2. I however am not patient. Thus I partly disassembled the booster to get the rod out. I then held the rod by the nut in a vise till I could turn it with a huge set of channel lock pliers. Worked like a charm. But I created alot more work for myself and potentially ruined the booster. It was all dirty and corroded so I took the opportunity to clean up a bit. Just hope everything sealed up when I got done.
Just a word of warning. There is a rubber disk at the end of the adjustment rod inside the booster. You can't see it normally. But it sometimes falls out and causes the brakes to feel weak. It will almost certainly fall out if you pull the rod in order to make the adjustment. To reach the rod with the pliers and wrench, have someone press the brake pedal so the rod sticks out enough for you to reach it. Or place a brick or something or something on the pedal to cause it to stick out.
You can leave the lines hooked up to the master if you are careful. They will flex and bend enough just don't bend them too much. So you can do thius job without having to bleed brakes again afterward. Also may want to have some gray rtv to seal the master cylnder back down to booster when you're done.
Here's a pic of the page about this in the FSM.
I got it from this thread by Zedyone_kenobi. He's goes into alot of detail about the adjustment when he replaced his booster.
http://www.classiczcars.com/forums/showthread.php?t=40535&highlight=brake+booster
Good luck.
Edited by EverRude
Got my float gaskets in. Thanks Bruce. Nice to see you guys were really awesome about tossing gaskets into a envelope and just charging me for a stamp rather than tossing them and a big box like some places and charging me twice the price of the gaskets for shipping and handling an uneccessary box.
Adjusted floats and installed. Sat down in car ready to crank her over and got nothing. Battery was dead. Dang it. Coulda sworn I disconnected that thing. Never good idea to leave a battery in an old car connected for days knowing it'll just be sitting there. Especially one with known wiring issues.
So the battery is now charging. It'll be the morning to actually crank her up. Meanwhile I tested brake lights. They work fine. Seems a PO bypassed the harness for brake lights and wired them with a bypass wire. So there's either a short in the harness or it was a bad attempt to avoid fixing another issue that was causing the brakelights not to work.
There's no Flasher switch in the car. Would not having a flasher switch cause issues for blinkers and brake lights?
I believe the turn signals run through the flasher, not the brake lights.
Here's a link to a printable wiring diagram:
http://www.classiczcars.com/forums/showthread.php?p=157255
John
I can't crank her now. I had been attempting to equalize carbs and she died mid tweak. Now I cannot restart. I started trying to set it back where it had been. Still no go. Sure she fires a second then dies. Choke on or off seems to have no effect. Getting fuel because I see the guage pressure and I pulled the hose at carb and let fuel run out.
While tweaking I noticed as before the aft carb was doing all the work. The front carb seemed to have no effect. I pull the forward float. Dry. Apparently the float adjustment I made is a bit excessive for that float. It shuts off the needle valve and allows no fuel in.
Is the float hieght the same for the original needles and his ball valve or are the needles set at a different height?
Anyways just posting to update status. SU's suck.... but I'm getting it. Bet once I figure this out I'll sing praises of SU. Right now though. I want a 10 pound sledge and no regrets.
