I have a 72 Z that I bought new from PaceSetter in Rochester. It has 242,000 on it. About a year ago I overheated it and it started blowing blue smoke. I figured I had melted the valve seals so over some time I got a rebuilt head and replaced it. Got it funning and it still blew smoke so I figured it need the bottom looked after. had arranged to take it to a place for the rebuild but now I can't get it started.
Everything seems to be normal up to the started motor starting.
So, I have:
Charged/checked the battery OK
I have taken the started motor to Kragens for testing OK
I have replaced the starter switch (not the key part) OK
I have replaced the coil OK
I have changed the ballast resistor
I have checked the starter relay.
So, when I try to start it, when I turn the key in the Acc. position all is ON and the radio comes one. When I turn to ON, the starter relay clicks.
When I turn to start the relay clicks again but nothing happens.
It is an automatic so I have also tested that switch too OK.
The coil wire to the distributor is intact.
I am at a loss. Any ideas would be appreciated.
https://www.classiczcars.com/forums/topic/35939-befuddled/
