I need the right side windshield squirter nozzle for my 73. I've found them online used, which is fine, but I remember a thread where someone was using a Maxima or some other model's nozzle, with better results than the originals. Does this ring a bell for anyone? I've searched, but can't find the thread I'm thinking about. BTW, here's a tip. If your nozzle is clogged, be very careful you don't snap off the sewing needle inside it when you are cleaning it.
Thanks,
Matt
I used a strand of copper wire to clean my plugged nozzle. I just stripped back a 10ga stranded wire, separated out the strands, and used them one at a time until the blockage was free.
Sorry, I don't know a good source for the nozzles.
