Skip to content
Dirty tank
I got a new fuel pump for my 77 280z , ran good for a while,then died. It was the pump full of rust, from the tank.Now the pump is dead, can someone tell me what fuel pump I should buy and were I can get it.Also what I should do so this won't happen again.
Thank you
You have rust in your tank. Search for " tank cleaning"; It should guide you in the right direction. When you replace the tank , Add a "g3" fram filter from pump to tank so it can catch any fine sediments in the future.
http://www.atlanticz.ca/zclub/techtips/fuel/g3filter/index.htm
Agreed, ...snip...
sorry, was thinking the 280's fuel pump was in line, and not in the tank. Had to edit
Edited by 70 Cam Guy
My bad
