I have a 79 ZX and the guy i bought it from found a mounting kit for a single din. Best I can say is find an audio shop and see if they can make something custom for you. they should be able to do something that looks good and fits correctly.
https://www.classiczcars.com/forums/topic/28263-radio/#findComment-249768
The aftermarket mounting kit is just a flat ABS panel to fit the radio pod and cover the extra space-trim a piece of cardboard as a template and cut one out of plywood, plastic, or sheet metal(brushed aluminum would keep a large part of the stock look).
Will
https://www.classiczcars.com/forums/topic/28263-radio/#findComment-249770
  • 3 months later...
