Skip to content
Remove Interior Tar Padding
Hit the pad all over with a hanner, then use a 5 in 1 or puddy knife and it lifts up in large piece's.
Yes , many times , at this time of year when the temp is cool it will come off as you has found. The majority of the time it chips off in stamp sized chunks. Dry Ice applied first making it brittle helps greatly. Over the past years, this has all been discussed several times. Gary
