my 77 has it. prod date 6/77.
it also has a 7lb lump of steel bolted to the bottom of the diff carrier..vibration damper i assume. i just HAD to ditch it. pshycologically, the car feels 100lbs lighter..LOLOL
If you're talking about the L shaped, layered thing that bolts to the bottom of the differential mounting member, I have that on my 78 also. I've never really figured out what that is either.
There is definately a thread on that. I had mine off when I replaced the for'd diff mount - the manual refers to it as a damper plate.
It was a pain in the nuts to reinstall.
hmmm :ermm: thats an odd part indeed. My 1977 doesn't have that. don't really see the need???? my best guess is maybe it was some sort of Kit Nissan added on as a dampner for people that complained about the common "Clunk" sound?? who knows.
Ya'll have that too?!
I only noticed it a couple times flooring hard left in 1st from nuetral.
Whats tha fix, tighten a bolt or something?
it also has a 7lb lump of steel bolted to the bottom of the diff carrier..vibration damper i assume. i just HAD to ditch it. pshycologically, the car feels 100lbs lighter..OL
You must be talking about this.
There was a thread on it and I think it helps absorb vibrations from the differentional that could be felt if I remember correctly. I will have to try and look up that old thread.
