July 13, 200718 yr comment_214984 Hey wingZro Befor you spend a pile of money on paint, you should try a mild/medium compound - polish and wax. You may be suprised. Link to comment https://www.classiczcars.com/forums/topic/24730-need-tips-on-buying-1977-280z-please/?&page=5#findComment-214984 Share on other sites More sharing options...
July 13, 200718 yr Author comment_215019 Yup,isn't that car in your avator from GT4? Yup that game is still great! Fastest time on Nurburing so far is 7:58'ish Sweet. Congratulations. Thaynx yo HAHA, Woke up this morning and found I loved it MORE Hey wingZro Befor you spend a pile of money on paint, you should try a mild/medium compound - polish and wax. You may be suprised. Diffenitely have to look into that compound for sure. Someone had the nerve to key the car befor I took delivery :mad: not bad though jus minor. Says "F@@@ U" above Driver door handle and "F@@@ U Sunny" on the roof above the driver side window just light enough and small enough to put a Nismo logo Decal over it if need be! ....... No Good Bums.... The exhaust things first cause I have to pass smog to get the Title registered in my name at DMV. I think the Problem is this, rusty exhaust pipe and possibly bad manifold flange gasket between where the manifold connects to the exhaust pipe. I think the flange gasket is rusted out somewhat cause the gasket between the engine block and manifold looks OK. Heres goes a shot of the engine compartment and the build date of 10/76 Link to comment https://www.classiczcars.com/forums/topic/24730-need-tips-on-buying-1977-280z-please/?&page=5#findComment-215019 Share on other sites More sharing options...
July 13, 200718 yr Author comment_215020 Also came with A/C that works. And was also part of some recall that got corrected as evidenced by a stcker on the back of the hood. Also the factory didn't write the Paint Color Number on the color decal so I don't what Ruby's true color ~Z~ Link to comment https://www.classiczcars.com/forums/topic/24730-need-tips-on-buying-1977-280z-please/?&page=5#findComment-215020 Share on other sites More sharing options...
July 14, 200718 yr comment_215024 Looks well cared for. As for the key job, was someone upset about not getting her?It may be the angle of the photo, but the fuzable links may need some attention. Link to comment https://www.classiczcars.com/forums/topic/24730-need-tips-on-buying-1977-280z-please/?&page=5#findComment-215024 Share on other sites More sharing options...
July 14, 200718 yr comment_215027 It may be the angle of the photo, but the fuzable links may need some attention.Or, at least they need the fusible link covers.Also the factory didn't write the Paint Color Number on the color decal so I don't what Ruby's true color Either the number wore off or the PO rubbed it off. From the little I can see in the pictures, it might have been the same color as mine (code 510 blue). Lift your rear shelf and look at the color in the spare tire well or inside any of the panels. Door, rear compartment, etc. Most people don't have those areas painted when the have a repaint done. Link to comment https://www.classiczcars.com/forums/topic/24730-need-tips-on-buying-1977-280z-please/?&page=5#findComment-215027 Share on other sites More sharing options...
July 14, 200718 yr Author comment_215029 Yeah I thought a Angry potential buyer keyed her too as it showed up about a week befor I brought her home.The Blue you see on the back of the hood Blake is actualy steel colored or primemer maybe. Everywhere I look including the Sprare tire, Doors and so on only show Red paint.In areas where paint is missing or chipped only reveals metal and no other colors show. If it was a repaint someone did a very good job of it.There is however some majoy overspray of Red paint thats been "clear coated" over the windshield weather striping.And theres this Neon Pink clay stuff on most of the seems and cowl vents that I thought was worn or fadded paint untill I looked just now and noticed it flakes off revealing nothing but good paint undeneath. Whats is this stuff?I'll post more pics of the above areas in the morning and get on ordering those Fusible link covers :rambo:~Z~ Link to comment https://www.classiczcars.com/forums/topic/24730-need-tips-on-buying-1977-280z-please/?&page=5#findComment-215029 Share on other sites More sharing options...
July 14, 200718 yr comment_215034 And theres this Neon Pink clay stuff on most of the seems and cowl vents that I thought was worn or fadded paint untill I looked just now and noticed it flakes off revealing nothing but good paint undeneath. Whats is this stuff?From that description it could just be wax that was missed. I use a xtra soft toothbrush to get the wax out of the nooks and crannies. Over time if it's left there it gets kind of clay-like. Link to comment https://www.classiczcars.com/forums/topic/24730-need-tips-on-buying-1977-280z-please/?&page=5#findComment-215034 Share on other sites More sharing options...
July 14, 200718 yr comment_215035 And was also part of some recall that got corrected as evidenced by a stcker on the back of the hoodI read a TSB (technical service bulletin) on that a few years ago at my buddy's shop. The BPT (Backpressure transducer IIRC) valve controls the amount of vacuum that goes to the EGR (exhaust gas recirculation) valve. All part of the smog control system. Apparently, there was some problem with the valve allowing too much vacuum which caused the car to emit too much nitrogen oxide from the exhaust which not only made the cars have difficulty passing the emissions test but also caused driveability problems. That sticker show that the valve was replaced with the upgraded one. Link to comment https://www.classiczcars.com/forums/topic/24730-need-tips-on-buying-1977-280z-please/?&page=5#findComment-215035 Share on other sites More sharing options...
July 14, 200718 yr Author comment_215055 From that description it could just be wax that was missed. I use a xtra soft toothbrush to get the wax out of the nooks and crannies. Over time if it's left there it gets kind of clay-like. THATS FUNNY :classic: I came to that same conclusion about 5 minutes ago when I took a look at her just now after I came home from work, then sat down and read your post I never thought some one could miss this much wax, especially an owner. Some one must been in a real hurry as this stuff is literally all over the car Funny thing is I took her to one of those so called "High End" automated car washes, .... yeah good job that did :cheeky: and already theres a fine layer of dust on the car. So it's gonna be me, a cheese cloth, wax, and that tooth brush Also I noticed theres alot of heat coming up through the shifter boot making the metal part of the shift handle hot to the touch. Is this normal or is there a bad seal some where under the boot between the transmission and center counsol thats letting the fumes get inside causeing my "exhaust leak" problem? Thinking about switching out the exhaust manifold for a 3 into 2 from MSA and replacing the entire exhaust pipe line after getting a tune up, that is if the tune up don't fix "the leak". The moter was running hot at around 240 in the beggining and the oil preasure wouldn't go past 2 or 6 lbs preasure :surprised. The car has been sitting garaged for awhile for the better part of 3 years, so maybe I'll do a complete fluid change befor checking gauges and electricals. ~Z~ Link to comment https://www.classiczcars.com/forums/topic/24730-need-tips-on-buying-1977-280z-please/?&page=5#findComment-215055 Share on other sites More sharing options...
July 14, 200718 yr Author comment_215056 Oh yeah, I only driven her twice on some what short runs yeasterday. She's been parked since last night jus to be safe. I walked to work :tapemouth Link to comment https://www.classiczcars.com/forums/topic/24730-need-tips-on-buying-1977-280z-please/?&page=5#findComment-215056 Share on other sites More sharing options...
July 14, 200718 yr comment_215069 My shifter warms up as I drive - I don't think it means anything. As long as it doesn't glow red Link to comment https://www.classiczcars.com/forums/topic/24730-need-tips-on-buying-1977-280z-please/?&page=5#findComment-215069 Share on other sites More sharing options...
July 28, 200717 yr Author comment_216816 Made an appointment to get my Valves adjusted on Thursday and the Lady, yes thats right a Girl , said it also sounds like my timing chain is loose and the timing is way advanced which is why my engine bogs and stalls on idle sometimes. Changed My Fuel Filter by myself yesterday and my gas came out looking rusty colored. Going to have the Tank dropped, cleaned and recoated in 2 weeks by a well known rediator shop in town. Turn around time is one week but the shop will not do fuel rails for safety reasons. Adding a new Fuel Pump when Tank is reinstalled, but do I need to clean the Fuel Lines and EFI fuel rails as well and should I clean the tank befor or after getting my Valves fixed. Link to comment https://www.classiczcars.com/forums/topic/24730-need-tips-on-buying-1977-280z-please/?&page=5#findComment-216816 Share on other sites More sharing options...
