I pulled my plugs today to see what color they were and I noticed that #1,2 and 4 were white while the others were black. My question is what could cause this? I recently adjusted my valves, it's got a new fuel pump, plugs etc. Timing is set around 8 degrees or so and the carbs are balanced. She idles nice at 800 rpms, and I'm running an e12-80 out of a ZX with an alt. conversion for more juice. I could understand that 1&2 could be slightly lean because they both feed off the same runner, but #4 has it's own and it's lean, I'm stumped. Any ideas out there?? Thanks
https://www.classiczcars.com/forums/topic/19552-3-lean-cylinders/
I've tried the colortune before and it showed all were running rich(yellow), couldn't really get them to reach blue so I tuned it by ear. The compression is good, around 170 across all cylinders and the plugs are gapped at .35. It burns a little oil due to bad valve seals, but generally runs decent. Sometimes it feels like the car is starving a little under accleration, but other times it's fine. Wondering if more fuel volume from an elec pump would feed the carbs better under a load.
The lean cylinders and if they were 1,2 and 3 or 4,5 & 6 then you could suspect a mixture problem from one carb . Tossing in the odd cylinder changes my thinking on this . However have you checked the fuel level in the float bowl on the front carb ? Also there are screens installed in the inlet of the carbs that could be clogged . Remove them there not needed , one could be blocked . Taking a compression test is good advise especially if this started happening after you adjusted the valves . Too tight of adjustment could cause a lean showing , also burn valves . You have great compression at 170 and being they are all close as you say is even better . Gary
The fact that you are showing a rich mixture with a color tune even thou you are showing a lean condition. I don't understand . Also you asked about adding a electric fuel pump for more pressure . If your pump is making 3 to4 psi. that is plenty . Providing it can maintain some pressure at speed . You don't really need a lot of volume . Before adding a pump check all filters and supply lines .
I recently cleaned out all my hard lines, installed new fuel hoses, new filter, removed the screens, etc, basically cleaned the whole fuel system. Also I checked my compression after my valve adjustment. I'm curious about my valves possibly being out of adjustment. Maybe I got this backwards, but I'm thinking that if it's lean that the intake valve would be too loose(not openening enough to let in fuel). Wouldn't a tight valve mean that it never fully closes all the way. My fuel pump idea comes about because sometimes at highway speeds when I try to accelerate it feels like it's starving for fuel, this doesn't happen all the time though, and never causes it to stumble, just not as much power.
