I just recently bought a 240z! (1972) I tune up the basics ( points, caps, plugs, ect..). Now I’m trying to get the carbs to balance. The airflow between the two carbs are extremely off. I’m getting 2 or 4 times more airflow on my rear carb and hardly any flow in the front. I thought it could be a vacuum leak, but I check it with the starter fluid trick. I haven’t top the SU carb oil yet and I haven’t check the valve clearance ( Should I?). Do i need to rebuild the carbs?
I’m pretty new cars :) . So be kind to me.
https://www.classiczcars.com/forums/topic/12118-carb-balance-problem/
honestly , you best investment is a video from z therapy , they have the basics tuning and its wonderful , you can also search for suggestions and such but the 15 or so bucks is worth its weight in gold for me , also get a sync tool , great investment
http://www.ztherapy.com
