I’m working on getting my 240 back in road shape and I tried to change the transmission fluid yesterday but the fill plug seemed impossible to remove. I ordered a 17mm square socket to hopefully not round it off and doused it in penetrating oil multiple times. Any other tips and tricks? When is searched around I read that applying heat to the transmission body around the nut can help, is a propane torch sufficient? Also, any guesses on what is causing the oil leak on the rear of the transmission and what the black oil soaked wire running to the rear of the transmission is? Thank you.
https://www.classiczcars.com/forums/topic/69655-transmission-fluid-change/
