In the process of accumulating parts to convert from the dreaded "auto" HVAC system to something manual.
In need of a used manual "water ****" valve assembly along with with associated air-mix door linkage pictured below. The valve need not be operational, I'm only interested in the linkage assembly and housing that bolts to the airbox - hoping someone can pull it off a parts car or something. Thanks!
Auto-to-Manual-Conversion12.pngNISSAN Genuine DATSUN 1979-1983 280ZX Heater Control Valve 27116-P6500 OEM - Picture 1 of 2
@preith I have a HVAC housing with a broken mounting ear that I would be willing to part out. Do you have everything else needed? I have several complete manual HVAC setups and one Auto setup.
Edited by kickstand80
Parts are located in North Dakota. If you want pix I can do that for you. I have been around this forum for a while and I make and sell Datsun Distributor parts that are NLA so there should be a few members that will vouch for me.
You can DM me, email me at chaug@bis.midco.net or text me at seven zero one - 471 - Fifteen Thirty four. If you google search Matchbox distributor breaker plate repair kit you will find me.
