78 280Z...stock exhaust system...muffler is rusting from the bottom... would like to solicit the forum expertise on the best way to proceed. The rest of the exhaust system is in great shape.
I'm considering 3 options...
1) Repair the muffler. Maybe use a couple of screen mesh patches along with a JB weld type product. A quick, easy, but only temporary repair. Car is garaged and is only driven a few hundred miles per year...never driven in adverse conditions...given that, repair would prolly last quite a while.
2) Replace the muffler with a similar (exact) sized replacement muffler....Internet search has revealed that OEM-sized replacement muffler options are limited...if I could find the correct sized replacement muffler, I think this would be my preferred option.
3) Install a "twin stack exhaust resonator" that I've had stored for over 30 years...see photo...not sure how loud this would be compared to "stock" noise levels....if it's not too loud, I'd be happy to go this route too.
I think that twin stack muffler will be way to loud without a serious resonator behind it. I do like loud cars and the Z’s sound awesome with some more noise but I think that muffler would be to much. But seeing as you already have it I would say it doesn’t hurt to just throw it on and see how she sounds.
As for repairing the old muffler I wouldn’t really recommend it. You could try but the steel usually isn’t the best quality which makes welding hard and it won’t look that good. So if you can spare it I would suggest looking at a new one, maybe a JDM dual stake muffler? I know Zstory from France has some nice option for stock US and JDM look.
I haven’t used anything from Zstory but I do find them very interesting. First up is getting my 280z on the road and then I can slowly move towards engine work for which I’m highly considering them.
zed2...thanks for replying...I'm in Oak Harbor, WA (it's in my signature)...I'll keep that in mind, but I think I'm gonna do a little more research before I'd consider buying an entire exhaust...my system seems to be in great shape except for the muffler...give me some time to eliminate all the other possibilities.
If you're going to have a muffler shop do it why not them look at it and use their database to find one.
If you're going to do it yourself, then trying the no muffler twin stack should be easy. If the dimensions are correct.
Looks like what you have is clamped on, not welded. So trying some things should be easy.
