280 Factory floor pan welds - Body & Paint - Classic Z Car Club Skip to content
Where did the floor pan lip weld. My original was over the groove and the groove was filled with a black material. Does it weld to the bottom lip of the groove?
Refer to the figure below (taken from the FSM), which shows how the inner and outer rockers and the floor pan come together. The arrow on the outboard flange of the floor pan shows how the flange aligns with the inner rocker.
Note the horizontal rib (with the 'hockey stick' shape at the forward end) that's pressed into Inner Rocker ('Inner Sill). The top of the Floor Pan's outboard flange (designated in the figure by the small black circle) should align with the lower edge of the rib.
The line of spot welds that joins floor pan to inner rocker sits about halfway up the floor pan's outboard flange (see photo).
S30 Rocker Panel - Assembly (FSM - Body).jpgS30 Body - Inner Rocker and Floor Pan.jpg
Edited by Namerow
My factory floor covers the groove and its filled with black goo
