June 29, 201411 yr Author comment_450649 Ugh i really dislike the stock ignition.. some weird things today.-set the points, they were well above 25 thou, set them to 19 thou -reset timing to 34 degrees total, no vac. I lost almost 10 degrees of advance from setting the points.-Checked coil voltage, there is no ballast resistor on my fender, but coil voltage is 8.8 volts roughly.-Checked Coil resistance, 1.6 ohms.All seems to be in order, but the car is running worse than before, i get misfire and very jerky throttle response in low rpm. Advancing the timing seems to resolve this. I might just give up on it until my electronic upgrade conversion arrives. Link to comment https://www.classiczcars.com/forums/topic/49380-z-therapy-su-carbs-not-running-right/?&page=5#findComment-450649 Share on other sites More sharing options...
