If you can help thank you
serge
I am looking for those parts ,my datsun is a 1977 280z,and my oil pan leaks even after changing the gasket at the Nissan dealership here in Tucson Az,and i was told that there are no longer avialiable..Does any one as a picture of those parts so i may go to the junk yard and know what to remove, or were i could buy some .
thank you for helping
From the Datsun / Nissan Parts Microfiche:
11124-R1000..............Reinforcement - Oil Pan (This piece goes around the rear of the engine, and along the passenger side of the engine.
11124-P6500..............Reinforcement - Oil Pan
11123-N3300.............Reinforcement with Heat S/Plate (This piece goes along the driver side of the engine near the Exhaust Downpipe)
11123-N4200.............Reinforcement with Heat S/Plate
The Datsun / Nissan Mircofiche does not specify a change over date from the first part numbers to the second.
thank you for the info,but what will be my chance to find it ???? also is it a must to have the Nissan dealer is telling me that this is the reason my oil pan leak,and there are the one who instaled for me.
regards
serge
They should be on all of the 280Z's, 280ZX's, and RWD Maximas in the junkyard. Both of my cars had them and I'm sure they help but I'm not convinced that you can't get the oil pan to seal without them.
