Posted April 15, 200916 yr comment_280866 So I've seen this simple mod / add on at the other sites I frequent.My newest car is an '04 Infiniti FX45, and this add on pertains to allcars with the PCV type system. It's a simple oil / air separation setupusing either a home made / store bought air compressor separator canthat's installed between the PCV valve and the carb/plenum/what have you.This traps the oily/fuel contaminated mist that's blown past the rings, stopping it from being sucked into the carbs or intake plenum in the caseof my FX. My 240z has a Crown turbo kit , and I think I'd have to add anextra one way valve because of the added pressure. Any ideas ? Myskills entering links to this topic are limited . Also an added benefit tothis would be no loss of octane due to oil contaminated air being burntin the combustion chamber that causes detonation and pinging. Does anybody have this setup ?:bulb: Edited April 15, 200916 yr by Unkle Link to comment https://www.classiczcars.com/forums/topic/31524-pcv-system-oil-catch-can/ Share on other sites More sharing options...
