When you Post a reply - to my reply - using the "Post Reply' buttom directly below the discussion (not the quick reply box).
If you scroll done the browser window, below where you type in your text - you will see a hyper-link in the area "Additional Options". In that area you will see a box titled "Attach Files" and in that box a hyperlink that says "Manage Attachments". hit that hyper link... and it will allow you to select any image on your hard drive to upload.. note that there are size limits
Use a .jpg image with a width of less than 1024 pixels.. and you should be fine..
try it..
Carl B.
ok i get to the point were i can upload the pics but when i do all it says is "Uploading pleaz wait" so i do....................and nothing happins is it something to do with my comp?
ok ok Everytime i do it it fails thats the problum there now how do i fix it?? or what can i do??
It is possible that the server is slow at that point in time. It is possible that your file size is too large, and your connection speed to the Internet is too slow.
How are you connected to the Internet? cable modem, DSL, dial in ???
What is the image size of the picture your trying to upload?
What computer are you useing?
Carl B.
