I find it hard to beileve all 6 injectors are clogged at the same time
but you never know, stranger things have happened.
Try BuDavids idea before you go buying injectors and what not.
Also do you remeber where the plug wires were set on the Dizzy in the beginning,
i.e. can you put them back the way they were?
yah i did.. and the plugs are sparking is it possible its just not enough spark?
Could be a few things,
1~
If your coil is shot it may not spark at all in my guess but at least you getting some spark for now.
2~
My fuel pump was bad and was running a good number of psi below
normal opperating preasure.
Sblake said I can change it myself which I did and now I notice a huge difference in the amount of GET UP AND GO even on 5 cylinders.
if your pump is bad you may hear it running but it may not be sending enough gas.
Did you say you smell no gas in the exaust as BuDavid suggested?
3~ Shot fuel preasure regulator IMO.
~Z~
could be a million things i guess... no gas on the exhuast what so ever and i cant get the injectors out to see if thats working. and im not sure real sure how to shock it anyway.
ok well i cant figure it out. i just dont wanna have to take it to a shop :(
Well for about a houndred bucks you can get a Diagnostic and that'll give you a complet list of everything you need to fix before it becomes a problem at least.
After that it becomes about the Duckets :mad: :dead:
BTW Did you change your Sparkers, how do they look?
~Z~
Slow down, you're jumping to too many ill-advised conclusions! The car has been sitting for 7 years? Do a fuel pressure check. The tank probably has enough sediment to restrict the pressure even if you've drained it a put in fresh gas. That doesn't clean the tank. That sediment also works it's way into the lines. Yes, you might see fuel leaks like you said eariler but if the pressure isn't enough the car won't run.
your right.
ok well again still cant figure out whats mounting the fuel rail so i cant check injectors crazy pressure is my guess cause i can loosen the lines to the injector and it sprays for awhile i think then injects themselves are clogged or broke or stuck or somthing. and at 38$ a peice its gonna be awhile before i can give u guys updates
