May 21, 200718 yr comment_210246 Follow up pictures... Link to comment https://www.classiczcars.com/forums/topic/24329-working-on-floor-pans/?&page=2#findComment-210246 Share on other sites More sharing options...
May 21, 200718 yr comment_210258 What I did on mine was cut out the floor just like you did, and then I cut out sheet metal pieces just bigger than the holes in the floor. Then I put a bead of window sealer caulk around the hole in the floor, set the metal on top, and screwed it in place. Then I fiberglassed around the edges, and grinded the screws tips off of the bottom of the car.THE ABOVE TYPE OF ''REPAIR'' IS WHAT CAN KILL YOU. All that is holding the new sheet metal in place is some window caulk and a few screws. The fiberglass over the rust will just allow it to continue to spread and rot away the metal until the floor falls through. Gary:rambo: Link to comment https://www.classiczcars.com/forums/topic/24329-working-on-floor-pans/?&page=2#findComment-210258 Share on other sites More sharing options...
May 22, 200718 yr comment_210299 Follow up pictures... Looks they did a great job there Randy. I hope you didn;t spend all your retirement or college funds on that. Link to comment https://www.classiczcars.com/forums/topic/24329-working-on-floor-pans/?&page=2#findComment-210299 Share on other sites More sharing options...
May 22, 200718 yr comment_210309 Jimmy - Looks to me that you're on the right track...and with the help of EarlyZed's photos, you should be fine. Best luck to you.GWGarrard Link to comment https://www.classiczcars.com/forums/topic/24329-working-on-floor-pans/?&page=2#findComment-210309 Share on other sites More sharing options...
May 22, 200718 yr Author comment_210327 Thanks for the pictures, they help alot.Jimmy Link to comment https://www.classiczcars.com/forums/topic/24329-working-on-floor-pans/?&page=2#findComment-210327 Share on other sites More sharing options...
