Posted March 26, 200619 yr comment_161001 Hi,Im back I do like reducing my fuel consumption by 54%I have that dam engine runing ok now.I have found I need sum 30 degrees vac advance, with cold airStill few things to sort out yet (another 200 hours+++)Im looking for a computerized ign system. The mega squirt system only goes to 50 degrees BTDCIve emailed them a month ago and no response yet.I will need to have an basic offset of over 70 degrees BTDC (even higher)and the ability to fire as late as 14 degrees ATDC.?????? Does anybody know where I could find such a beast?????I will start porting the Z engine soon.My PC based system is ok, but its only for tunning an engine.I have still a bit more programming to doso that I can tweek the main timing curve in time it takes for 10 sparks to elapse at any rpm. sum stuff n results2.0 L Stocker early 80's setup in a wagon withPorting by me.....comp ratio 10.5:1 running ULP (will try BP 98 later.)43.7 MPG taking it easy @80 to 90 km/h and climbing 800 feet over 200 kmsUnconfirmed return trip ~50 MPG Thermal efficiency ~61.3% if I did the figures right !.. Link to comment https://www.classiczcars.com/forums/topic/19376-ive-got-54-better-mileage-now/ Share on other sites More sharing options...
March 27, 200619 yr comment_161073 I dont know what your smoking.. but its viscously attacking you Advancing too much = pinging and a ruined, overheating engine Link to comment https://www.classiczcars.com/forums/topic/19376-ive-got-54-better-mileage-now/#findComment-161073 Share on other sites More sharing options...
March 27, 200619 yr comment_161158 In case you didn't notice we're in australia buddy. We don't use miles or gallons here. Link to comment https://www.classiczcars.com/forums/topic/19376-ive-got-54-better-mileage-now/#findComment-161158 Share on other sites More sharing options...
March 27, 200619 yr comment_161183 Come on guys, you're giving him exaclty what he wants. Responses. I can't even see his post since he's on my ingore list. You do recall some of his previous topics? IMO, just let it drop right off the front page. Link to comment https://www.classiczcars.com/forums/topic/19376-ive-got-54-better-mileage-now/#findComment-161183 Share on other sites More sharing options...
April 26, 200619 yr Author comment_165118 In case you didn't notice we're in australia buddy. We don't use miles or gallons here.ok so its around 5.5L to 7L per 100km on the hwy with carefull driving.and can use ~1.5 L /per 60 seconds at the top end Link to comment https://www.classiczcars.com/forums/topic/19376-ive-got-54-better-mileage-now/#findComment-165118 Share on other sites More sharing options...
April 26, 200619 yr Author comment_165120 I dont know what your smoking.. but its viscously attacking you Advancing too much = pinging and a ruined, overheating engineIts an experment in the boundry layer of air.spark plugs do tell how an engine is running?have a look at these plugs with stock dissy.http://smokingwheels.myphotoalbum.com/view_album.php?set_albumName=MyEngineIve att the current timing curve toomy sparkplugs are running a little hot but there 3 heat ranges up from STD,my pistons still are black with carbon so im in no danger there.oh and the flow tests dont show much resistance in the whole induction system just look at the timing curve at 3000 where most engines flatten outcheers Link to comment https://www.classiczcars.com/forums/topic/19376-ive-got-54-better-mileage-now/#findComment-165120 Share on other sites More sharing options...
