280z 1976 parts darom - Part 2 - For Sale - Classic Z Car Club Skip to content
  1. AFM #1, $100, at some point of its life it was rebuilt (there is a sticker). When I purchased my 1976 280z in 2009, the car had a running engine with this AFM. The PO opened it up at some point (the cover wasn't properly glued). The AFM passed all the test per FSM, page EF-51 - EF52. Pins 8 & 6 = 182 Ohm, 9 & 8 = 103 Ohm, 36 & 39 with flap closed - no continuity, 36 & 39 flap at 8 or more degrees - continuity, air temp 75-80F, 27 & 6 = 2 kOhm, 27 to ground - no continuity, applying 12V to 9 & 6 -> voltmeter leads on 8 & 7 - while opening the flap, voltage decreases.
  2. AFM #2, $200. I bought a re-manufactured unit sold by the Python Injection company in 2011 (sold on Amazon, have a receipt, the car has had 985 miles since then). The unit was never opened, and is an excellent condition. Very clean inside. I passed my CA smog multiple times with this unit, I have a smog certificate from 2017 if the buyer would like to check out my CO, HC, and NO numbers. Per FSM tests: 8 & 6 = 181 Ohm, 9 & 8 = 104 Ohm, 36 & 39 flap closed, no continuity, at 8 degrees or more -> continuity, air temp 75-80F, 27 & 6 = 2.14 kOhm, 27 to ground - no continuity, applying 12V to 9 & 6 -> voltmeter leads on 8 & 7 - while opening the flap, voltage decreases:
  3. Aux Air Regulator #1. $60. Part A32-600000 UNISIA JECS, made in Japan, tt was installed on my stock 76, applying 12V, it takes about 5 min to close:
  4. Aux Air Regulator #2, $60, Part 22660 45POO, A32-618 M14, Jecs. Tested, takes about 7 min to close. Attention: the connector's top plastic notch is to the right side. It can be filed off to make it work with the stock 280z connector:
  5. Aux Air Regulator #3, $60, part 22660 20P10, A32-000 M13, Jecs, takes about 6 min to close. Attention: the connector's top plastic notch is to the right side. It can be filed off to make it work with the stock 280z connector:
  6. 1/1976 Fuel Tank, will need to be boiled off/potentially re-lined due to the some corrosion. The tank never sat with used bad gas, i always filled it up with the off-road no corn additives gas during the winter storage. The overall condition is good, with one dent at the bottom (see the picture with an arrow), $200 (prefer a local pickup in Madison, WI, the shipping will be around $160 in a nice s30.world box):
  7. Ignition Transistor unit, $40, part E12-12A, removed from my running car.
I prefer paypal for payment or Zelle.
Thanks,
Den
Edited by darom
the AFM #1 is gone.
