The engine ran and connected to gas tank hasn't ran since
If one mistakingly reverse the return line and the fuel line will it ruin the fuel pressure regulator. Also does the ECU have to screwed to the bracket to make a ground and will this cause it not to start?
Thanks for any help:
Edited by gas4765
