I would NEVER put jack stands on the frame rails like that. Especially holding up the whole rear of the car. That's Suicide.
ZKars had the best suggestion. Pockets are fine but use the rear crossmember frame, just inside of the pockets. This will spread them out and allow for movement under the car.
I already gave him that exact answer for the rear in a Private Message. My photo and explanation in THIS thread is for the front only which is the correct spot. Should have continued through PM to avoid confusion (My Fault) Not trying to go against you dave but I have always followed the FSM and have put my stands there for supporting the front with no problems at all. Always Nice and solid with no movement. That photo was a while ago when I replaced my Tie rod ends and ball joints. That photo isn't the best either. The jack stand kinda appears further back than it really is.
Edited by DatsunZsRule
