Went to install the PerTronix points replacement kit last night, and I'm a little concerned. I removed the vacuum pot to check the range of motion on the plate, and I'm worried the igniter wires will bind when the timing is advanced.  See below. Retarded (OK): Advanced (not OK): Should I be concerned, or am I just being paranoid?  Any suggestions on how to reduce/eliminate the interference?  Feedback from others who've performed this install appreciated.  Thanks!
