Strange early z car electrical issue after being driven.........
The 200 ohm setting is the correct one. The reading for the first test should have been close to zero. The reading you got was >200. That means either you didn't have good contact on the testing points, the diode is bad, or something else is wrong with the wiring.
The way to confirm is to put the alternator back in, connect the battery, put the key in ON, and check for voltage to ground on the white/black wire. If you don't have voltage under those conditions, the alternator won't charge when running.
@SteveJ
Thanks for the information, I am going to go retest and make sure I got it right. I did check the diode plug with a meter, and it looked right.
I think I have another diode plug too, so will try that and see if anything changes. So to make sure I am right, I should have the positive on the ballast resistor and the negative on the alternator plug and should get close to "0"?
Am I correct that there is only one fusible link coming off the starter that feeds the car on the early z? For some reason in my brain I thought there were two..... not sure what that would be for........
Will get the alternator checked on Monday, since I have it out. Then reinstall........ THANKS so much for the information and quick response.......
Edited by 70z4fun
Of course, there is one other possibility. I could have designed the test wrong. I dug out a diode that should be the same spec as the ones used in the plug and tested myself. I found my instructions were lacking.
You should re-test with the meter in diode testing mode.
You can leave the key in OFF, too. If you test from the ballast resistor to the white/black wire, you should get a result similar to this:
With the leads swapped, you should see this:
If you do the voltage test, you should see a little less than battery voltage as the diode causes a slight voltage drop.
Edited by SteveJ
@SteveJ
Ok, tested it with the current diode plug
Here are the results:
With Positive going to ballast resistor:C97B7930-9B5C-4FCE-8D3A-57DABC0A7BB9_1_105_c.jpeg
With Negative going to ballast resistor
Will get the my current alternator checked out Monday, and I will check the one I had on before I got this one.
Did not find the other diode plug that I had as a spare, but will look for it on Monday. The "new" is slightly melted the white plastic on top
Well, the diode seems to check out. Test for voltage at the white/black wire with the key in ON when you get the alternator put back in.
On 12/6/2025 at 6:38 PM, SteveJ said:
  1. Put the key in ON without the car running.
  2. Check for voltage to ground on the lower pin of the T connector on the back of the alternator (white/black wire). It should be about battery voltage.
Without this the diode and alternator problems won't matter. No voltage, no charging. This can be checked with the alternator removed. Also, might as well check both pins. The top one should have battery voltage also.
Yes, it can be checked, but there is a risk of shorting out the fusible link if the owner does not insulate the end of the alternator wire properly. I try to lay out the tests to minimize the chance of introducing another problem.
I did get the alternator checked out atNAPA, tested good,,,,, so will put it back in the car. Is there a fusible link on the charging system?
I will test for 12v at the t connector when I get back together. Gives me something to do on Tuesday after work. Thanks for the advice….
