New member - Nismo fuel pump install no voltage at the pump. Also coil and ballast wireing help needed.
Up front in the area of the console look for blue tape around the wire harness. That's where you should find the female plug with 2 wires. Put a jumper across the plug and you should then have power back at the tank for the electric pump. It's a good idea to put an inertia switch in the jumper loop to shut off the pump in the event of a crash.
