I have been planning to put triple Webers on both of my cars since 2019 and have been searching and sometimes posting in this sub-forum for a while. I now expect to be putting the engines together over the winter.
While folks talk about their various starting and running problems, jetting recommendations, and so forth, what I've noted is a general lack of pix showing the details of the various setups that must be out there. I've only seen one AFAIK in a post from 2023 (https://www.classiczcars.com/forums/topic/68479-triple-webers-setup/#comments).
Could those of you who actually have triple Webers take the time to produce both general and up-close pix of your linkages (OEM pedal to throttle bar or cable) and the various options for mounting (soft or hard mounts; studs or bolts, etc.) and linking (or not) the carbs and why you went the way you did?
In conversation with Pierce Manifolds, I've learned that there is actually a "left-handed" cold start module, which would integrate with the existing S30 choke cable setup. The default cold start unit (right-handed) only works if it gets pulled from the front of the engine. So, did anyone ever install a pulley system to allow use of the R/H cold starts with the OEM choke cable setup?
https://www.classiczcars.com/forums/topic/69619-detailed-pix-of-weber-setups/
That's quite understandable as those of us "up North" don't drive our beauties in the winter and those of us "down South" probably have temperatures that allow for choke-free operation the year round. But maybe someone in the Northwest uses them and it would certainly be good to have this knowledge available on CZCC,
Of course, because Webers and Mikunis have completely different operating mechanics from our SU carbs, coupled with changes in fuel compositions since the 1970s, it could be that cold start units simply are obsolete.
Have you looked into “OER” carburetors from Japan. Eiji @Datsun Spirit uses them exclusively. I’m going to run a set on my engine he built. My understanding is there design is a mixed hybrid of Mikuni & Weber.
If I remember right, the Webers have an accelerator pump. So you can pump them a couple of times and omit the choke...provided they have fuel in the float bowls
