Posted June 9, 20196 yr comment_577248 What is the recommended sealant used to secure the rear tail light lens to the bulb assembly housing? There are two slots in the rear plastic lens on the lower part which at my best guess is to let water out if it does get in? Can anyone confirm if this is what these are for and if that isn't the case, what are they for. Thanks in advance. James Link to comment https://www.classiczcars.com/forums/topic/62303-tail-light-lens-to-housing-sealant-help/ Share on other sites More sharing options...
June 9, 20196 yr comment_577251 Here's what I went by years ago and they turned out very well. Hope it helps. Thanks @Dr. 240Z  Link to comment https://www.classiczcars.com/forums/topic/62303-tail-light-lens-to-housing-sealant-help/#findComment-577251 Share on other sites More sharing options...
June 9, 20196 yr comment_577255 2 hours ago, 240znz said: There are two slots in the rear plastic lens on the lower part which at my best guess is to let water out if it does get in? Can anyone confirm if this is what these are for and if that isn't the case, what are they for. That is exactly what they are for and originally there was a small rectangle of felt covering that slot on the inside to keep water from pushing in through those slots but allowing it to drain out if it did get in, most of those felt pieces are long gone so if you have access to the inside now is the time to replace them. Link to comment https://www.classiczcars.com/forums/topic/62303-tail-light-lens-to-housing-sealant-help/#findComment-577255 Share on other sites More sharing options...
June 9, 20196 yr comment_577257 As I understand it, the felt covers were provided to keep bugs from getting inside and turning the light housing into insect housing. Probably also help to keep out road dust. Link to comment https://www.classiczcars.com/forums/topic/62303-tail-light-lens-to-housing-sealant-help/#findComment-577257 Share on other sites More sharing options...
June 9, 20196 yr comment_577277 Just one suggestion to the OP's question. Instead of using silicone to seal the lens to the taillight, I would suggest butyl strip caulking. The stuff is black and is non-hardening and waterproof. It used to be called dum-dum (no, I am not making this up). 3M, Eastwood and a bunch of other companies make it. Comes in 3/16" diameter ropes that you set into the grove where the lens sits in the housing. My local auto parts store sells it by the one foot strip (2 required per taillight) for $.30 each. Just cut it where necessary for the drain holes in the bottom of the housing/lens. This will allow you to remove the lens at some point(s) in the future - if necessary - without damaging it. One warning; it does stick to everything - kind of like anti-seize! Link to comment https://www.classiczcars.com/forums/topic/62303-tail-light-lens-to-housing-sealant-help/#findComment-577277 Share on other sites More sharing options...
June 10, 20196 yr Author comment_577336 Yep, dum dum is also used to fix the plastic sheet between the door card and the door. From memory, it is a water barrier or something like that. That stuff is very tacky and is the reason my drivers window shattered when cleaning it off, don't ask, amateur mistake, lucky the parts car glass will be used. I remember some white felt plugs that I pulled out years ago. Previous owner had used silicon to stick them in place, took an age with a careful blade to extract the lenses. Scratched them a bit but not that you will ever see. Thanks for the prompt replies guys. It's been a while since I posted on here and wondered if it still the place to go for info, sure is, cheers. James Link to comment https://www.classiczcars.com/forums/topic/62303-tail-light-lens-to-housing-sealant-help/#findComment-577336 Share on other sites More sharing options...
