Sign in to follow this
zcardepot.com
Fuel Injection Injector Conversion Bungs 280Z
EFI conversion bungs for a stock 280Z, 280ZX intake manifold.  If you are looking to upgrade injectors for performance or turbo applications or simply want a better quality injector for stock applications this is the part you need.  These billet aluminum bungs adapt the standard Datsun seal over to a modern O-ring style of injector found on most modern EFI cars.  In most cases the new style injectors will require a different fuel rail than stock.
https://zcardepot.com/fuel/fuel-injection/fuel-injector-adaptor-bung-efi-280z-280zx.htm
Share this post
Link to post
By using this site, you agree to our Terms of Use. We have placed cookies on your device to help make this website better. You can adjust your cookie settings, otherwise we'll assume you're okay to continue.
