Seat panels
Packerz
Looking for molded plastic panels/covers that cover the S30 first gen Z  (280Z) seat hinge assembly.  These cover the bolts located on drivers and passenger side hinge assembly for seat back adjustment/rear deck access.  They clip on and look like a wide legged cap? They are also found on inner as well as outside-upper two/seat back and lower two for bottom cushion attachment bolts.
also looking for:  handbrake/parking brake switch (push-in socket with white plunger button and green/yellow stripe spade male lead and black male ground wire.lead from switch.
also, black rubber caps that slide over metal rod of seat track adjuster under/front of seat.
thank you,  Doug.      Prefer E contact:   dbparker54@yahoo.com
