Valve adjustment help!
OneMaybe2
Ok, I haven't done a valve adjustment since I bought the car which was roughly 9 months ago. I purchased it from someone who had been working on it and it was in pretty good shape. Today I go to adjust the valves and when I lift the valve cover, I notice the Pivot lock nuts are much bigger than any manual said they should be. I haven't been able to find an L28et that looks similar to mine with the cover off. Maybe I'm not looking at it right but I thought I would ask before I started loosening the nuts. Also there aren't two nuts like the manual says, just that one lock nut.
I also tried to get the feeler gauges through just to see If there was any clearance. and I couldn't get even the 0.0015" feeler through with the cam lobe pointing straight up. Is there something I'm missing?
(another note: The lock nut on there is bigger than 22mm, which was the biggest wrench I had on hand)
Looks like a confirm. This is a snipped out of the 1983 280zx factory manual, it looks like at the very least '83 zx turbos had hydraulic lifters that look like what you've got, and I found at least one google hit for somebody who swapped them out for solid lifters using a timesert threaded insert that fit the large hydraulic lifter hole on the outside and a junkyard earlier z solid adjustable lifter on the inside threads.
Beware of capslock: http://www.cardomain.com/ride/3839420/1981-nissan-280zx/page-6/
I also found another forum mentioning that they've seen P90 heads with hydraulic lifters and P90A heads with solid lifters, so sometimes it can be a bit of a crapshoot of what lifters a given head might have circa 1983.
What this means for practical purposes, is that your valves are (or should be) self adjusting with oil pressure. If the lifters stick in the up position, however, they can cause valve float just like too-tight solid lifters and will need servicing.
Edited by Captain_Zeros
  • 1 year later...
Check the side of the head between 1 and 2 spark plugs. It should read P90A. These heads with hydraulic lifters came out in Feb 1983 on the turbo zx's.
Parts for the lifters are very hard to find these days. If they are working good, they are very quiet and very little valve train noise. I have heard of (never seen it) an adapter for them to convert then to normal adjustable lifters.
Chas
Here is another thread dealing with a P90A. He had trouble and his conclusion to change tomechanical lifters is purly based on his set up and different to your situation.
http://www.classiczcars.com/forums/engine-drivetrain-s30/20617-p90a-hydraulic-cam-problems-still.html
Edited by EuroDat
