Classic Zcar Club The BEST place on the Internet to obtain support for those SU's!
Go Back   Classic Zcar Club > CARS ! > 240z, 260z, 280z Forums > Help Me !!
Help Me !! This is the emergency HELP ME forum for those of you that are having troubles with your Z-Car and need immediate help.
User's Login
User Name
Password
Remember Me?
Main Menu
Module Jump:
Supporting Members
Old 02-02-2010, 10:52 AM   #1
v4vAnimalMother
Registered User
Default Low compresson
I have 74 260z. Last fall just before I was about to put her into storage it blew the water pump. Anyways I put her into storage early with plans on replacing it after Xmas and a new roof.
Anyways, I did a compression test last night and came up with these numbers:
1# - 100
2# - 100
3# - 105
4# - 107
5# - 105
6# - 100
Is it just me or are these really low? I'm not a mechanic, just starting to learn as much as I can. I do have a backyard mechanic helping me though that said the numbers were good because they were close to the same but after reading through other posts I think they should be around 150. If so what should be my next move?
v4vAnimalMother is offline   Reply With Quote
Old 02-02-2010, 11:35 AM   #2
Diseazd
Registered User
Diseazd's Avatar
Default
First thing.....adjust your valves to .008 intake .010 exhaust. Then do another test.....if you don't get an increase in compression, you have somewhat of a problem. True, no cylinder should be 15% off of another, but 100 lbs. is too low. Probably needs rings. Should be reading 160 or so. Good luck!
__________________
http://www.flickr.com/photos/1404980...7600346077563/
______________________________________________
http://www.flickr.com/photos/1404980...7603350695459/
70, 71, 72 & 73 240z
90 300zx
Diseazd is offline   Reply With Quote
Old 02-02-2010, 11:37 AM   #3
ChrisZ
NUTs according to wife
ChrisZ's Avatar
Location: Denmark - in front of my coffee, behind the laptop
Default
Your backyard mechanic is somehow right, the wear on your engine is equal on all cylinders, try to add a squirt of oil in to the cylinders and make a new compression test, if the numbers goes up, you have worn rings, there is much more in to this, more than i will try to explain in another native than my own, others might want to chime in.
Chris
__________________
-73 240Z HLS30-171039
-66 Roadster SPL311-05204
ChrisZ is offline   Reply With Quote
Old 02-02-2010, 11:44 AM   #4
jmortensen
Registered User
jmortensen's Avatar
Default
Compression testers (especially cheap ones) shouldn't be used to measure the pressure in a cylinder accurately. They really should be used to compare one cylinder to another as your friend said. What you have there looks good to me, if there aren't other problems I'd drive it, and if there are I'd suggest a leakdown test.
__________________
Jon
"Erupt into a Bev-Rage this summer with Glug!" - Dan Halen
jmortensen is offline   Reply With Quote
Old 02-02-2010, 03:47 PM   #5
carrott
Registered User
Default compression rods
Good advise, get a good compression tester and only do a "running Temp" test ,ie warm engine up to operating temp, remove all plugs , ground coil lead ,hold throttle fully open (2nd person) and crank engine.Full pressure should be achieved or close to it in 3 compressions ,if it is relatively even ,all good.If they are all even but low add a little oil, wind over engine to seal against cylinder wall , if test shows a marked increase then rings would be problem, if on the other hand only one cylinder is low adjust valve to spec if no improvement , then possible valve . Again it is critical to warm engine up, as you said engine has been sitting so there could be some rust under the valves which will eventually wear off.
Good luck
carrott is offline   Reply With Quote
Old 02-02-2010, 06:18 PM   #6
d240zx2
Registered User
d240zx2's Avatar
Garage
Default
Don't forget to replace the water pump....!
__________________
First & Third owner of HLS30-00721
15 April 1970 Original Purchase date
B&V Motors, Lubbock, Texas
Sold in 1977. Repurchased in Feb '07.
Making up for the 30 lost years...
Frank in The Woodlands, Texas
d240zx2 is offline   Reply With Quote
Old 02-09-2010, 10:21 PM   #7
rjk629
rjk629
Default
deffinatly do a wet test with oil in the cylinders if it goes up you have ring trouble. funy story i couldn't get my 240z to run right and with different sets of carbs the same cylinders would not run. so i did a compression check my highest was at about 95 the next two were at about 60 and then the worst were at 30!!! god damn it sure explained why the damn thing would not run. anyways new motor now. totally rebuild l2 with 4 screw round top su's. nothing like a rebuilt motor
rjk629 is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
No Low Headlight Beam Function jwc4248 Electrical (S30) 5 09-20-2009 10:47 AM
Myth or Reality, low backpressure=low torque whamo Exhaust (S30) 34 10-11-2008 02:18 AM
Low Oil Pressure??? Mike Abild Engine & Drivetrain (S30) 3 12-25-2006 10:23 PM
No Low Beam Lights Wiper Problems MESSEDUP280 Electrical (S30) 2 06-18-2004 06:23 PM
Low Oil Pressure 280zgod Engine & Drivetrain (S30) 1 06-17-2004 08:15 PM
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
