User's Login
Main Menu
Supporting Members
06-27-2007, 03:05 PM
#1
Registered User
Its time to go ,,,,,RB30-ZED
Yes after 22 years im selling my 1973 240 Zed. In 2000 I striped it back to a bare metal shell and started a 2 year rebuild, using many new and rebuilt parts. One of the states best panel tradesmen spent 350 hours on the body and paint; this is one of the straightest Zeds you will ever find. I then spent over 18 months developing and installing the engine, driveline, suspension and brake systems. The programmable engine management system which comes with a laptop computer, security device and manuals, makes this car behave and drive like any new car. At the last National Concourse in Phillip Island this car ran a credible 2:03.65 for my first time at the circuit, and regularly runs in the low 1:13s at Wakefield Park.
This car carries a full engineering certificate issued in NSW.
See photos. http://picasaweb.google.com/RB30ZED
Engine:
RB30 with RB25DE VVT ported head.
ARP head studs and big end bolts.
New 0.5mm OS factory pistons give 10.7:1 compression.
Tomei cams fitted.
New RB25DET oil pump running on modified wide drive crank.
6.5ltr trap door sump.
Custom oil returns.
All oil galleries in the block crank and head threaded with screw in plugs.
Kalmaker engine management.
Custom exhaust with long secondary pipes to large resonators.
Drive line:
Skyline RB20DET double syncro box rebuilt with upgraded bearings.
Custom tail shaft with larger uni’s.
R180 viscous limited slip diff (3.7:1)
New front and rear wheel bearings.
Brakes:
Dual master cylinders with Tilton balance bar.
296mm front and 300mm rear disc
Ferado DS2500 pads.
Suspension:
Koni top adjustable inserts in shortened struts
All ball joints new.
King’s prosport springs 3 sets, 325, 300, and 275#
Adjustable spring platforms.
Rose joint front control arms.
Well balanced F & R sway bars.
Adjustable rear end.
Under chassis brace.
Wheels and tyres:
Genuine 16X7 Pannasports
Toyo RA1 225X50X16
Electrical:
Rewired, main harnesses and fitter relays for H4 headlights, VVT engine management and starter systems.
Hidden engine harness.
Rebuilt alternator.
Indicators moved to park lights and park lights in head lights.
Body:
350 hour spent on body and paint.
Zero rust.
Fish oiled regularly
Diablo Red
Original front panels painted and stored to replace front spoiler.
New badges for bonnet and rear quarters.
New inner and outer kick plates
New door rubbers
New glass channels
New front and rear windscreen rubbers
New windscreen
Interior:
Re-skinned dash.
New carpets
WRX seats
Original and 4 point harnesses.
Custom rear strut brace connects side panels to strut tops, and mounts harnesses.
G-tec meter
Spares:
Original seats
Original front indicators
Original engine block with matching engine number.
Original steering wheel
Diff
F & R brakes
Factory 260Z mag wheels
Price: $ 28000 Aust.
Contact: Steven Davis rb30_zed@hotmail.com
06-27-2007, 10:05 PM
#2
HS30-00352, HS30-101370
Good luck with the sale Steven. I'm sure that the new owner will wear a wide smile for a very long time.
__________________
Zed not Zee
HS30-00352 still being rebuilt (year 6)
HS30-101370 chopped in half
CZCC #1608
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
